stock rev limiter
twofourzeroSX
Car: 91 sileighty
hey whats the stock rev limiter on the blacktop sr20 ecu?just makes me kindof nervous because i hit 7500 rpm's twice today when my tires were spinning and ive already spun rod bearings in my sr20 once b4
Blown240sx
Car: 1996 240sx
twofourzeroSX
Car: 91 sileighty
ok it just scares me to see my RPM's that deep in the red. then againn i guess i could just let off the gas.....hmm
Morph
Car: 91 Sr Powered Coupe
Blown240sx wrote:7500
Not saying you are wrong but i over reved my to 8 and engine didnt hit the limiter. Maybe the 1st guy i had put the motor ****ed up some how but just to let ya know 240. Just be careful. + you dont need to rev an sr to 7500 unless you are far from stock.
pearlS13
Car: 90 240sx
an sr with a stock t25 will make its peak power anywhere between 6-6.5K rpm so there really isnt much point to go all the way to 7500....sounds pretty sweet bouncing off the limiter tho with a 3 inch exhaust!
Morph
pearlS13 wrote:....sounds pretty sweet bouncing off the limiter tho with a 3 inch exhaust!
Modified by Morph at 11:41 PM 10/13/2006
efrain240sx
Car: 1992 nissan 240sx HB
I thought sr's ecu didn't have a rev limiter. I could be wrong sorry if I am.
Blown240sx
Car: 1996 240sx
They have a factory rev limit that has fuel and ignition cut.
twofourzeroSX
Car: 91 sileighty
yeah u are definetly past the power band..but when u have a lightened flywheel and LSD and ur commin around a turn w/ both tires spinnin the thing revs up REALLY quick, sometimes too quick for me to react. when im going in a strait line i NEVER bring it past redline.
Blown240sx
Car: 1996 240sx
rev limiter doesnt always hit right at 7500. Ive hit 7585 on my Power FC so I know it can go past it but not much.
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
i thought redline was 7500 and the limiter was higher
Blown240sx
Car: 1996 240sx
What? That makes no sense. Why would they set a redline at 7500 but allow you to rev higher?Trust me its 7500 Ive got data to prove it off my Power FC. Ive hit it plenty of time since traction can be an issue with 300hp in the 240.
drifter_for_life06
Car: Daily: '16 WRX
Exocet
redline i.e. the red area on the tachometer..and the limiter is farther
ive been told its 7800
Blown240sx
Car: 1996 240sx
I was told cows can fly but thats not true. The SR stock rev limiter is 7500 trust me. The analog needles in cars arnt that acurate. My tach might show close to 8 grand but the power FC tells me exact. The Power FC comes with all factory settings including rev limiter.
