Stock Rb25det runs with 0.1 bar boost only
momenfathi
Car: Cefiro a31
I did rb25det conversion to my cefiro a31, after conversion I had problem that the boost would not go more that 0.1 bar, I disconnect the wastagate hose and the boost go higher than 0.7 bar. I changed AFM and sparkplugs, tested the WG, coil packs and CAS and I did boost leak test but still same issue.
What should I do?
Note: the engine all stock and the current mods are:
-3 inches exhaust
- 255 lph walbro fuel pump
- 3 inches FMIC
eds13
Car: 89 240sx Hatch, 07 Armada LE, 91 Skyline GTR
Double check and make sure you have a good boost source without any T's going to the wastegate. If you do and it doesn't your wastegate flap might have broken off.
momenfathi
Car: Cefiro a31
eds13 wrote:
Fri Dec 28, 2018 7:43 am
Currently the boost source connected to the nipple in the cold side pipe, and running the stock setup for boost solenoid.
What do you suggest?
