stock rb25 turbo
jingledic
around how many pounds do the max out at on a rb25
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
its been covered a million times...
14psi is max for effiency. But they have failed at all boost pressures up to that point even at factory levels.
whitebride91
Car: 91 240sx fastback
i know this thread is old but i have one of these and does anyone have any specs on it. AR? Trim? i only know the limit before it breaks and that its a ceramic bearing turbo.
RustspecS13
Car: '74 260z and '88 300zx turbo
Are you going to put it on a KA or something? The most common failure point for RB20 and 25 turbos is 13psi and up. My rb20 turbo stock boost is 10psi and I'm not even going to up the boost.
I would just get a l28ET or VG30ET turbo. Its pretty much the same size as the rb25 turbo except it has a steel exhaust wheel and a larger turbine housing. Its still a t3 flange.
~Alex
Joe
jesus SEARCH SEARCH SEARCH
anything over 12psi makes it a timebomb.
