Stock Radiator for sr20det
portisroads
I'm thinking about getting this engine. All if you could look it over and give me your opinions. I also need to know will the stock radiotor work for sr.
CTC stainless steel equal length headerCTC T3/TO4S hybrid, 60-compressor wheel, w/ .63 A/RTial 40mm wastegate w/ .8bar springstainless dump tube for wastegate, vented to atmosphereOil feed and return lines, stainless braided hose with aeroquip fittings 3" air intake with couplers, clamps and air filterShorty downpipe with 2 o2 bungs welded in, and 3-bolt flangeStainless braided hose for crank case, and K&N breather filterInstallation/break-in instructions, and guarantee information
comp tested and we run a link down test
Complete S13 SR20DET Engine 1998cc Displacement 205 hp@6000 RPM and 203 lb-ft at 4000 RPM 8.5:1 Compression Ratio Garrett T-25 Turbo w/ T04B Compressor Wheel 370cc/min. Injector Size. S13 5 speed RWD Transmission. Engine/Gearbox/ECU/ has all sensors and nothing is cut. 90 day waranty.
I want you to tell me how much you think you would pay for all of this. It has a really clean pic to. If someone could tell me how to post a pic I'll put it up.
