stock R33 GT-st Fuel Pump
300Plus
Car: 1995 S14 w/ Rb25det Series II
I searched for the answer but found none. What HP does the stock R33 fuel pump support? what does it flow? thanks guys
Modified by 300Plus at 2:05 PM 7/22/2005
300Plus
Someone has to know? I mean does it compare to the Walbro ? i heard there's no point to upgrade to the Walbro if i have to R33 Gtst fuel pump.
gawdzilla
Car: none
you might be in luck. according to FAST, the fuel pumps between the rb25 and rb26 are the same. according to http://www.stealth316.com/2-fuelpumpguide.htm - "From what I have read at various web sites, the R32 Skyline came with a 190 lph pump, and the R33 Skyline had a 195 lph pump. I am not sure about the current R34 model. In the April 2004 issue of Turbo & High-Tech Performance magazine, a stock R33 Skyline GT-R fuel pump was tested to flow 252 lph at 43.5 psi and 13.5 volts. "
300Plus
sweetness good to know. I was thinking a Walbro might still be needed but obviously not. thanks alot man
