Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Wed Oct 30, 2002 8:25 am
Since the Japanese don't use the term Horsepower [an English creation designed to confuse people] and derived much of their early technology from the Germans ..............how much horsepower is not germain!
Because whenever a Horsepower race gets going the marketers pressure the engineers to do things that enhance this peak number and you end up with cars [G35 and Q] with high numbers that are meaningless in the real world but the cache of having the most horsepower at a high rpm.
How do two different cars: the same weight, the same gear ratios, the same drivers, the same everything except one has 30 HP more accelerate the same............the shape of the torque curve and the self propensity of their engines to accelerate underload.
The early Q had more than the translated [from the Metric System] Torque!
The torque reached a peak of 307 lb/ft vs the 292 published rating at 4,000 rpm. The translated torque had two bumps at 5500 and 6,000 rpm in the downward slope from the peak [4,000]. They were 265 and 243 lb/ft respectively. Both of these translate to 278 HORSEPOWER at 5,500 and 6,000 rpm.Between these two peaks was [is] a tuning dip of 4% translating to 269 HP.
The english system of measurements makes it very difficult to translate power into acceleration EASILY.
The 307 lb/ft can be improved to almost the theortical limit by the JWT ecu [by 10%] to 337 [give or take a few] removing all the extra fuel richness [and overheat safety cooling] and advancing the timing at 4,000 rpm to the ragged edge of destructive knock with suitable fuel!As the rpms increase above 4,000 the VE falls and the engine needs [can use] more advance as the pressure drops. The factory was conservative to prolong engine life so fine tuning and optimization can increase the HP by 10% to 307 HP [269 lb/ft] at 6,000 rpm [the numbers just happen to be the same so many get confused with stock vs JWT enhanced programming].
What really counts is friction decreased rear wheel Torque and HP[ if you must use the term]. The highest rear wheel torque I have ever seen quoted or measured is a peak of 264 lb/ft at 4,000 rpm on premium non oxygenated gasoline after 6 dyno runs [the more runs you make the hotter, the thinner, all the fluids are so the numbers go up sequentially [255>256>260>263>264...264].
The stock Q peak rear torque is around 233-238 lb/ft at its peak roughly 30 more than that of the G35 AT car depending on the lubricating fluids and their temperature.
What each engine is ...is what each engine is.Pretty amazing we can still get a dialog going about a 15 year old design............maybe people realized this in 91 because this was the highest year of Q sales approaching 15,000! vs maybe 4,000 in each of the past few years.
278 HP sold more then than 340 does today? And $51k today is certainly less than $39k was in 1991!
