stock oil pressure gauge (where do wires go?)
krayton
Ok, ive been meaning to do this for awhile. I have the wire that goes to the stock oil pressure gauge, just need to know where it goes on the engine. I tried tracing it through my harness, but lost it somewhere in a relay/ fuse box.
anyone know? i wanna just get it working so my whole cluster works
Andrew85cm
Car: 89 240sx with RB20det
I am not the best person to have wiring information but I happen to know this answer. Right beside the oil filter is a yellow plug in the block where a sensor goes. That is the oil pressure and oil light. There should be two wires that go into the block in this area. Trace those two wires....I don't remember the colors just look...inside to the ecu or one of those 2 white plugs. It could be on either. I would have to check to see what I did. Then splice in a wire and connect to the appropriate wires on the cluster. There are two one is for the oil light and one is for the gauge...I think. I will check the colors and get back to you.
Mind you I can't get my tach workin' so take this with a graind of salt. My oil pressure gauge does however work. (that is the only thing working currently however)~ANDREW~
blk90s13
thats true i seen the sensor its like 4 times as big as the ka sensor on my RB20
Wulfgang
Yep, 2 wires. Are you using the RB cluster then? Cuz the KA doesn't have an oil pressure gauge.
I used the KA cluster and lower harness. So I just found out which of the two wires was the oil pressure switch and wired it into the KA lower harness where the original KA pressure switch was.
Andrew85cm
Yeah I am using the RB cluster and RB lower harness. I got to figure out the problem with the tach today what fun!~ANDREW
krayton
thanks for the info guys
andrew, shoot me an email if you need some help with that.
[email protected]
