Stock Oil Gauge question
Encryptshun
Car: 2005 Nissan Xterra
Okay, as it says in my Avatar, I have an '05 Xterra. VQ40DE, 4x4 w/towing package. Between idle and load, my oil pres gauge moves between hovering about one needle-width above "low" to just about halfway to the high mark. Is this normal? I know I have the correct filter, oil viscosity, and oil volume in the engine, and it's been this way since I bought the truck.
Encryptshun
Bump for no response yet?
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
My trucks are previous generation and just have idiot lights for oil pressure, however, some fluctuation in oil pressure is normal, usually dependent on engine speed and load.
Encryptshun
Desert Rat wrote:My trucks are previous generation and just have idiot lights for oil pressure, however, some fluctuation in oil pressure is normal, usually dependent on engine speed and load.
Absolutely. But my fluctuation is 50% of the total gauge area. I'll give Nissan a call, but I wanted an "unbiased" report from some Gen 2 owners before I did that.
dustinmc
Car: 2005 Xterra 4x4
I just purchased the same model (2005 Xterra 4x4 auto) with 15,000 miles and noticed the same thing after I left the car lot. It concerns me because cars I have owned in the past do not do this. The oil pressure is low at idle and fluctuates depending on the engine rpm. I would like to know if all 05 and newer Xterras do this or if it is a problem that needs to be fixed. Was searching the forum to see if others have the same issue or if something is wrong with mine. Please reply if you know!
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
8-9 PSI at idle hot.No spec for RPM.Not to worry.If oil pressure reads its all good.The resistance of the senders are broader than other manufacturers.
Encryptshun
NM50 wrote:8-9 PSI at idle hot.No spec for RPM.Not to worry.If oil pressure reads its all good.The resistance of the senders are broader than other manufacturers.
Thanks for the response. Now that I'm creeping up on 50K miles, I'm getting a bit tetchy about my oil pressure.
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
This is normal. The oil pressure gauge is fairly sensitive. Oil pressure is never constant in a car and when you get on the gas it will pick back up. I have an 05 Xterra and i get the same thing. No worries. You will get a warning if the oil pressure is too low. In this case the needle would read 0 and then if the pressure gets lower the light comes on.
