Stock oil catch can.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
What does this do exactly? Could i just get rid of it and run a longer hose down to the block instead of to the can and then to the block? Does anyone know where to buy that clear braided oil resistant tubing that comes with the catch cans? I know this has been covered before but i cant find any info on removing this can.
S14toRPS13
It's suppose to catch the oil from the blowby that way they don't go into your intake tract through your turbo and so forth.
OM3GA
Yeah, i understand that but ill be running a baffled can between the valve cover and intake tube so would the stock catch can still be needed?
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
from what i've heard/read, the stock one is baffled..
EnjoiNismo
Car: 93 240sx
I still use my stock catch can.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Run a tube from the motor to the valve cover with an elbow. Then run another tube from valve cover to catch can. Then leave the other line vented on the catch can. I wish I had some pics, I thing you'd like the idea. Before I didn't run a catch can at all...just a line from motor to valve cover w/ a k& n breather but it lightly coated that area of the engine. Now its good. I just used coolant heater hose.
codyace
Car: S14 w/redtop
Rear motor vent, to stock oil seperator bottom
Top of stock oil seperator, to Valve Cover T
Valve cover T, to catch can.
other side of catch can, to intake, after MAF, before turbo
To easy.
OM3GA
codyace wrote:Rear motor vent, to stock oil seperator bottom
To easy.
Yeah this is how i had planned, however i have to do it before the MAF So i hope this doesnt cause any problems. It shouldnt unless oil is going through the can and into the maf i suppose.
