Stock Nissan and Infiniti Offsets
phenryiv1
Car: 2003 Sentra SE-R SpecV
Please add any CONFIRMED offsets for stock rims here. Please QUOTE my post, insert your addition, and make the new post. NOTE: All wheels listed here are 5-lug applications. Please make a seperate list for 4-lug wheels.
This may want to be "stickied."
Nissan:
15" x 6.5" 95-99 Maxima SE/GLE 40mm 16" x 6.5" 97-99 Maxima SE 40mm 16" x 6.5" 00-01 Maxima SE/GLE 40mm 16" x 6.5" 00-01 Maxima GXE 40mm 17" x 7" 00-03 Maxima SE 45mm 17" x 7" 02/03 Maxima GLE 40mm 18" x 8" 350Z 30mm
Infiniti:
15" x 6.5" 96-99 I30 40mm 15" x 6.5" 96-97 I30t 45mm 15" x 7" Q45t 36mm 16" x 6.5" 98-99 I30t 45mm 16" x 7" Q45 40mm 16" x 6.5" 00-01 I30 45mm 17" x 7.5" Q45t 30mm 17" x 7" I30t 45mm 17" x 7" I35 40mm 17" x 7" I35 sport 45mm 17" x 7" G35 45mm 17" x 7" G35 sport 45mm 17" x 7.5" 02 Q45 40mm 18" x 7.5" Q45 45mm 18" x 7.5" M45 35mm 18" x 8" G35 coupe 30mm
Centerbore on all 89+ Nissan/Infiniti cars is 66.1mm.
BuudWeizErr
S14 SE: 16*6.5 +40R32 GTST: 16*6.5 +40R33 GTR: 17*9 +30R34 GTR: 18*9 +30
all i know.
hannibal
Car: Red Line to Glenmont
I believe the exact center bore is 66.06mm. And I assume the Nissan GXE/GLE/SE wheels you listed are from the Maxima.
240sx info15" x 6" 89-94 240sx 40mm15" x 6" 95-98 240sx base 40mm16" x 6.5" 95-98 240sx SE 40mm
I'll let you edit your post if you agree...
Edit: I just looked at the Wheel FAQ sticky. Most of this info is already in there. Take a look and see if you have anything new to add to that...
phenryiv1
IWannaS15 wrote:I believe the exact center bore is 66.06mm. And I assume the Nissan GXE/GLE/SE wheels you listed are from the Maxima.
240sx info15" x 6" 89-94 240sx 40mm 4 lug?15" x 6" 95-98 240sx base 40mm 4 lug?16" x 6.5" 95-98 240sx SE 40mm 5 lug?
Good point on the "Maxima" being left out. I saw that center bore listed somewhere else, and that 66.1 was what my Mille miglia rims had on the hubcentric ring, but your 66.06 mm spec is most likely the most accurate measurement.
Is the bolded text that I added in my quote above correct?
phenryiv1
ChunkiDori wrote:S14 SE: 16*6.5 +40R32 GTST: 16*6.5 +40R33 GTR: 17*9 +30R34 GTR: 18*9 +30
all i know.
Are Skyline wheels equal sizes front and rear?
I am wondering whether my G35c/350Z info might not be inaccurate based on F/R differences. I believe that they are different F&R...
hannibal
See my edit above. your specs seem more exact and you include offset.
yeah youre right about the 4 lug vs 5 lug on the 240sx. sorry!Those Skyline sizes look familiar. Ive never seen someone specify front or rear for Skyline wheels though, so I assume theyre the same.
Z32 info16" x 7.5" 90-96 300ZX NA +45mm16" x 7.5" 90-96 300ZX TT front +45mm16 x 8.5" 90-96 300ZX TT rear +35mm
got the Z32 sizes from http://www.wheelspecs.com/specs/wheelbrands/94and they do list different sizes for front and rear on the 350Z
hannibal
Z3317" x 7.5" 03-up 350Z Base/Enthusiast front +30mm17" x 8" 03-up 350Z Base/Enthusiast rear +33mm18" x 8" 03-up 350Z Performance/Touring front & rear +30mm18" x 8" 03-up 350Z Track front +30mm18" x 8.5" 03-up 350Z Track rear +33mm
Exar-Kun
Car: 2005 350Z
I'll compile all this sometime later in the week..good work guys..
(I've been busy job searching and stuff...sorry..)-chet
barrigas14
G35 coupe is +30 on 17" and 18"
btw the coupe rims are also 17x7.5 front and 17x8 rear
szh
Car: 2018 Tesla Model 3.
[quote=" phenryiv1 Please add any CONFIRMED offsets for stock rims here. Please QUOTE my post, insert your addition, and make the new post. NOTE: All wheels listed here are 5-lug applications. Please make a seperate list for 4-lug wheels.
Nissan:
Infiniti:
15" x 6.5" 96-99 I30 40mm 15" x 6.5" 96-97 I30t 45mm15" x 6.5" 90-96 Q45 45mm15" x 7" Q45t 36mm 16" x 6.5" 98-99 I30t 45mm 16" x 7" Q45 40mm 16" x 6.5" 00-01 I30 45mm 17" x 7.5" Q45t 30mm 17" x 7" I30t 45mm 17" x 7" I35 40mm 17" x 7" I35 sport 45mm 17" x 7" G35 45mm 17" x 7" G35 sport 45mm 17" x 7.5" 02 Q45 40mm 18" x 7.5" Q45 45mm 18" x 7.5" M45 35mm 18" x 8" G35 coupe 30mm
Centerbore on all 89+ Nissan/Infiniti cars is 66.1mm. [/quote]
I added my limited knowledge of 90-96 Q45 in bolded italics above.
Z
phenryiv1
szhosain wrote:I added my limited knowledge of 90-96 Q45 in bolded italics above.
Z
Nice. By the time this is done, it should be a nice resource for people wanting to keep stock specs, or those wanting to keep NissanMoCo rims on their Nissan/Infiniti...
szh
This includes additional info on 2003-2004 G35 Coupes.
Quote »Originally posted by phenryiv1Please add any CONFIRMED offsets for stock rims here. Please QUOTE my post, insert your addition, and make the new post. NOTE: All wheels listed here are 5-lug applications. Please make a seperate list for 4-lug wheels.
Nissan:
15" x 6.5" 95-99 Maxima SE/GLE 40mm16" x 6.5" 97-99 Maxima SE 40mm16" x 6.5" 00-01 Maxima SE/GLE 40mm16" x 6.5" 00-01 Maxima GXE 40mm17" x 7.0" 00-03 Maxima SE 45mm17" x 7.0" 02-03 Maxima GLE 40mm18" x 8.0" 350Z 30mm
Infiniti:
15" x 6.5" 96-99 I30 40mm15" x 6.5" 96-97 I30t 45mm15" x 6.5" 90-96 Q45 45mm15" x 7.0" Q45t 36mm16" x 6.5" 98-99 I30t 45mm16" x 7.0" Q45 40mm16" x 6.5" 00-01 I30 45mm17" x 7.5" Q45t 30mm17" x 7.0" I30t 45mm17" x 7.0" I35 40mm17" x 7.0" I35 sport 45mm17" x 7.0" G35 Sedan 45mm17" x 7.0" G35 sport 45mm17" x 7.5" 02 Q45 40mm17" x 7.5" 03-04 G35 Coupe 30mm (front)17" x 8.0" 03-04 G35 Coupe 33mm (rear)18" x 7.5" Q45 45mm18" x 7.5" M45 35mm18" x 8.0" G35 Coupe 30mm
Centerbore on all 89+ Nissan/Infiniti cars is 66.1mm.[/quote]Z
s14brent
Car: 07frontier 4x4 6spd!
someone should finalize the list and make it a sticky!!
phenryiv1
It is a living document at the moment. When we get closer to "done" it will be stickied.
SmithSR
Car: 240sx
phenryiv1 wrote:Centerbore on all 89+ Nissan/Infiniti cars is 66.1mm.
Up to 2000, all Sentras and 200sx(FWD Sentra variant) with 13, 14"(Base models) wheels had 4-100 bolt pattern and 59.20hub bore. All 200sx with 15" were the common 4-4.5 with 66.06hub bore
phenryiv1
SmithSR wrote:Up to 2000, all Sentras and 200sx(FWD Sentra variant) with 13, 14"(Base models) wheels had 4-100 bolt pattern and 59.20hub bore. All 200sx with 15" were the common 4-4.5 with 66.06hub bore
My statement should have said "Centerbore on all 5-lug 89+ Nissan/Infiniti cars is 66.1mm."
Sorry for the confusion- this thread was intended to chronicle 5-lug wheels.
SmithSR
Car: 240sx
Everything else looks really good
