Stock N/A SOHC problems
skylinekin
Car: 1990 Nissan 240SX Hatchback
My car is running like crap, the car will Idle smooth at 800rpm, then after a minute or so it will slowly drop down to less than 500rpm. If I tap the gas it dies, but if I slowly ease on the gas it will rev up. While driving basically the harder you press the gas the slower it goes, The timing is set at TDC. Here are a few videos, after driving it or reving it for a while it wont start at all.http://s34.photobucket.com/alb...3.flvh ... lb...1.flv
Thanks for the help.
benemorius
Car: s13, s13, eg, e36
Is there a reason you have the timing at tdc right now?
skylinekin
no, what is it supposed to be? 15 degrees btdc?
benemorius
Yes. Do that and then see what your symptoms are.
skylinekin
okay, I will do that tomarrow and see what happens.
skylinekin
yup that was the problem, I also put in a 300zx fuel filter. The only other problem is a slight hesitation at 1500-2500rpm.
