Stock manifold modded to except ext gate
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
I have seen a pics or 2 on here of guys who have modded there stock rb25 manifold to except a ext wastegate. I have searched and cant find them now when I need them.
Were exactly are you guys welding the ext gate?
jdmser
Car: duh
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
note the placement above the manifold flange for the turbo, keep the w/g as close as possible to the turbo flange so it prevents creep and uneven pressure in the turbo manifold
rb25drag
thanks guys. Exactly wat i was looking for.
krayton
does anyone know what the stock manifold is made of?
or how to weld to it? i thought it was cast iron, and that its a ***** to weld.
or your suppose to heat it up and braze it, then cool it very very slowly
anyone know?
black240jl
Car: black 240sx
h
jdmser wrote:
hey man im about 2 hours away from you, anyway you could make my manifold like that?
jdmser
Car: duh
It is cast. The guy who welded mine for me used to weld for the largest nuclear power plant in the US. He used a blow torch to heat it up and then tigged it.
black240jl-I can check to see if he's interested but, it was kind of a friend of a friend deal.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
You can also use nickel rod for it.
240z4u
Car: '95 Nissan 240SX
Its much closer to a cast steel, it welds just like steel too. Better safe than sorry though, preheating is the way to go here. You need to use nickle rod, plus it looks cool!
My guy had an easier time welding the manifold than welding the flange onto the stub of pipe. I used schedule 40 black pipe as reccommended by James Thagard years ago. This is my second manifold setup like this.
Keep the pipe stub as short as possible for expansion/contraction purposes. This matters most if your recirculating the w/g and don't use a flex coupler of some sort.
zer...17144
Evan
