240slidekat »
https://forums.nicoclub.com/240slidekat-u23506.html
Sun Jan 22, 2006 7:19 pm
is it possible that it is opening but the hole, restriction, and location of the wastegate is not suffecient enough to push all the air out and the air that was not pushed out goes to the turbo which causes it to boost higher?
This is what happens when i try it. ill put it on second gear and go full throttle and it will hold at 8 psi (which is the right pressure of the spring) for about 2 seconds and then 4600-4700 rpm the boost will rise up and keeps on going. it went up to 15psi at one point. i have a t4oE,t3 with .63 a/r intake and .63 a/r exhaust. dont know if that helps.
