Altered »
https://forums.nicoclub.com/altered-u169241.html
Mon Oct 26, 2015 12:56 pm
My tire is less than an inch away from the strut, and the only other things to come really close are the muffler mounts on each side. Being my exhaust is aftermarket this may not be the same with OEM mufflers, but the hanger that protrudes through the rubber exhaust mount is very close to the tire when my suspension is loaded. It isn't close enough to touch, so I am not concerned with it. Technically, I could fit a slightly higher offset, MAYBE a +50 without touching, but the way it is now it as close as I'm comfortable with.
A 20x11 +55 with 315/30 20 would fit exactly the same on the suspension side while keeping the outside from protruding at all on stock suspension. I forgot your car doesn't have the lowering springs mine does when I posted the offsets on the 20th. The 20x11 +45 might sit a wide tire further out than you like.
