spitalul2bad »
https://forums.nicoclub.com/spitalul2bad-u98702.html
Tue May 05, 2009 1:49 am
Unless you're a VERY experienced driver, don't get the 2 way. You'll end up wresling the car into stability at every corner, not only on acceleration. Braking, turning and powering out of corners will be like stuffing a monkey in a cage. Doable but needs a bit of a tussle.
If you're going drifting, get the 1.5.
If you're going racing... get the 1.5.
If you have a TRACK ONLY car and wanna learn to drive the hell out of it... get the 1.5.
If you have balanced brakes, great suspension and a huge FEEL for the car, not to mention how good a driver you are (ON THE TRACK, street doesn't count), get the 2 way.
If you're going drag racing (really?), get the 1 way.
Good luck.
P.S. Remember that you'll need MAINTENANCE on the diff. Fluids, clutches, and so on.
