Stock KA24DE piston tolerances
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
Hello, I am rebuilding a spare KA motor and I found a rebuld kit that comes with stock pistons, I was wondering if the stock (new) pistons could handle 10-12 psi and about 300-320 HP?I know this is a noob question, and I did search a little bit. What do you guys think?
also here is the kit I am thinking of purchasinghttp://www.importperformanceparts.net/imports/ ... ssan1.html
It's all the way at the bottom of the page. I believe its the very last one. Its either that or I will be getting a gasket set and some forged pistons. But I think the forged pistons are overkill for my goals.
Ligouri Rd
Car: '96 Nissan 240SX
That power level has been done with stock pistons. If your gonna build it anyway why put the effort in and go cheap with stock pistons?
emperor_lunchbox
money
emperor_lunchbox
what do the stock pistons max out at. If they will handle 15 - 18 psi and about 375 hp then I dont see why I would pay for aftermarket.
steebypue
im very interested myself. i would like to do the exact same thing
my question is:
on that link you provided with the engine rebuild kit, i noticed it didnt include sleeves.
would the old sleeves be ok after a rebuild?
also, they sell oversized pistons, does that mean its ok to bore out the old sleeves? or should i get new sleeves to bore?
is there anything i should do to the crank?
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
There are no sleeves in most nissan steel blocks bore and your good to go. I think darton makes sleeves for a rb26 but you have to do some major machiening to implant sleeves into a solid block. Somone correct me if im wrong as im not an engine builder.
steebypue
i was under the impression that the ka24de was sleeved from the manufacturer
240sxs1377
Car: 1993 240SX
no they arnt sleeved because they are solid so they dont need sleeves. but the sr20's are sleeved becaue they are alluminum bolck with steel sleeves. and the ka is solid cast iron block so they would not need them.
steebypue
thanks for clearing that up
emperor_lunchbox
any info on the tolerances?
