stock ka24de injector lag times
bentvalves
Car: 89 Silvia K's
Hi all,Does anybody know the latency of stock ka24de injectors, which Im assuming are 270cc squirters.
please correct me If im wrong.
thanks
Greg
I've seen .92 .88 .77.........???
Modified by ks13 at 6:59 PM 2/1/2008
justjuiceit4
Car: 1993 Nissan 240SXs, (Coupe and Convertible) 1994 Infiniti Q45
Any particular reason you are trying to find this out?
bentvalves
Car: 89 Silvia K's
jesum-makro.....you took the time to post that!?
A car I am working on is said to have 740cc nismos, I believe them to be stock ka24de injectors.
LAG TIMES PLEEEEASE!)#()#(&!(!
neverlift
if your looking at the tune to see the latency go to hybridka.com, or maybe try the ka or 240sx section and maybe he will respond... I cant recall off the top of my head so best bet is to look.
480sx
Car: 1996 Pearl White 240sx
It would probably be a little ezier to do a visual check of the injectors first. If you find out they look exactly the same as stock ones, then you need to do your lag time test or w/e.
