kool-aid54 wrote:how much punishment will the stock internals take. will they take a turbo and nos. If they will take turbo how high boost? I want to make my turbo project as cheap as possible.
This depends on your definition of punishment. No cast piston will stand up for very long to hard or sustained detonation for very long at all. But they should be able to take a pretty good amount of reasonable cylinder pressures. Doubling the power does not double the peak pressures. The same way we look at the area under the curve of a dyno chart for an overall picture of performance, the same should be done for peak pressures insude a combustion chamber. Adding boost generally increases pressures the most after peak pressure is already obtained. At double the power, you may only expect to see a 50% increase in peak pressure.
Detonation on the other hand, can easily see peak pressures and heat 10 times the peak pressure of normal combustion. This can do some damage very quickly. Forged parts can't even stand up to sustained detonation. The tempurature of parts starts to rise very quickly when detonation occurs. Too much heat not only make detonation more likely to happen, but softens the metal and allows it to fail more reapidly.
The point is, control detonation and you'll probably not see a problem running a moderate to high amount of boost, even on stock internals. This is assuming of course that there are no issues with your motor.
