neverlift »
https://forums.nicoclub.com/neverlift-u39984.html
Sun Dec 02, 2007 3:48 pm
I'm still on stock injectors I run between 6 and 8 psi depending what my IC wants to do lol... base pressure is way up tho, and I removed the stupid fuel lines that are bolted to the manifold, 255 walbro and z filter... ROM TUNED, is only reason I havent blown.
You could also thread the wastegate arm and lengthen it to lower your boost, but spool will be hurt! Also for 7 psi take out 5 or so, dont rev past 6grand so the stock ecu can read the knock sensor or you could unhook the w/g like florida said, I did it for a day when I lost my little clip
