Liquid_Neon »
https://forums.nicoclub.com/liquid-neon-u9864.html
Wed Apr 25, 2012 10:23 am
Might need a replacement, went to drive it today and cylinder #1 is dead again. It has been leaking for a little bit cause i would often find plug #1 covered in fuel and the car would start hard and miss there. I could until today take the plug out, clean it and put it back together and have it fire right up.
Well doesn't seem to be working now for me, I dont have all my tools so i cant check anything else. The last time i went over the car for a miss i had checked all electronics, wiring, spark, and injector pulses. #1 was/is the culprit and i swapped everything but injectors and it never moved.
also.. quick thing, i have never removed the injectors from this car. How are they held into the rail? I have swapped some on a chevy plenty and they are just really tight fitting o-rings once u unbolt the rail they pretty much can be twisted around and they pop out.
Yes i rebuilt my motor and NEVER removed the fuel rail from the lower manifold... im odd like that.
TLDR: i want a price on 1 and/or a set of factory ca18det injectors please and thank you!
