Carl H wrote:they physically will not fit into the rail, nissan changed rail and injectors midway thru production run.that and you really dont want those injectors anyways as they have a tendency to fail...not too too bad on an na car but horrible on a boosted car.
For more info on the failures see this link:
http://www.jimwolftechnology.c...E.pdf
I think that JWT also used to have a doc which showed all of the Nissan injector connectors (some are rectangular and the newer style have rounded corners). Anyway, can't find it, but it's all been covered before: the injector connectors are different, the manifold holes are different, the materials are different (early style seem to fail prematurely in the presence of ethanol and other additives), the wiring uses was different (though this is a function of the car, there's nothing stopping you from putting a relay in the early style car so that the injectors are only "live" when the key is on)
