stock ignition timing?
L0sT
what should the stock ignition timing be on a 1992 240sx? 20 degrees?
[s3]
yep
alex7542
Car: Racing and high horsepower
heyHow do you know whats 20 degress 15 degress 5 degress. can you explain to me how the timing isnoticed by degress. im not sure exactly were u know what degress its set at and stuff. is it set with the crank or the distributor or what. can someone explain to me how to read it and figure it out.thanks
[s3]
Use a timing gun.
alex7542
yea but the timing gun doesnt it jsut flash a light. and where do u put the light. im new to all this timing and stuff. im not exactly sure how it works and i want to learn. thats y i asked.in other words how does the timing gun work.
[s3]
To put it simply
1) Clamp timing gun pickup clip on spark wire going to cylinder 1
2) Start up car, let idle
3) Aim timing gun at pulley w/ timing marks on it
4) Look at mark on pulley to indicate what the timing is
Boostedka
Car: sex, and turbo charging rides
Pulley has a pointer.
Aim light there and count marks in accordance to FSM
Timing is 20 deg BDTC
alex7542
ok yea i figured it out already. i jsut didnt know how you know which markin is 5 deg 15 deg or anything. but know i figure it out its in the fsm.
L0sT
there should be 6 marks if im not mistaken
--- -5
--- 0 tdc
--- 5
--- 10
--- 15
--- 20 <---stock timing on a dohc
cory2081
Car: '07 Nissan 350Z
you guys forgot to mention to unplug the TPS sensor before starting the car to set the timing(or is that only on s14s)
L0sT
oyea, good question lol...i duno either
alex7542
i still dont get it how exactly the timing light works. you have to read the marking on the pulley. but when do u read them or what. does the timing light blink when it hits compression stroke or something i dont know. i know how i have to put the timing light but i dont know anythign else.
alex7542
What happens if the timing of the car was set at 0 degress tdc. thats what i set mine up to when i replaced my head. what affects would happen. its a completly stock car too. if not i have to set it at 20 degress but on compression stroke right. so in other words when the pistion is going up or going back down. can you guys please clarify this thanks.
cory2081
your car would be very sluggish at 0 degrees, slow revving.
alex7542
aa i dont remeber it being luggish at all. and to me it reved up fine. jsut incase this is how i set my time i put the crank at tdc on the red mark on the pulley in compression stroke on piston number one. then i place the distributor on cylinder one. and it started right up before. and now it has no spark.
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
alex7542 wrote:What happens if the timing of the car was set at 0 degress tdc. thats what i set mine up to when i replaced my head. what affects would happen. its a completly stock car too. if not i have to set it at 20 degress but on compression stroke right. so in other words when the pistion is going up or going back down. can you guys please clarify this thanks.
For the KA24DE the ignition timing is 20 degrees before top dead center. That means the spark plug fires 20 degrees of crankshaft rotation before the piston reaches the top of the compression stroke. When you clip the timing light onto the #1 spark plug wire, it turns on the light every time that plug fires. Shine the light on the crankshaft pulley and the pointer.
Make sure you disconnect the throttle position sensor first. Turn the distributor untill the last line on the right of the pulley is under the pointer.
| | | | | | -5 0 5 10 15 20 (degrees BTDC)
Quote » jsut incase this is how i set my time i put the crank at tdc on the red mark on the pulley in compression stroke on piston number one. then i place the distributor on cylinder one.[/quote]
Thats how you set it when you have the timing chains off to get it to run. Now you have to do what I mentioned above to 'fine tune' it while the car is running.
alex7542
ok perfect i got it. now i understand how it works. i wasnt sure u connect the light to were but now i got it. were is the tps located at in the 240. and thanks a lot leper
leper421
The connector for the TPS is near the throttle body to the right. Its a large gray connector with three wires (Light green w/ red stripe, black, white [the colors may be different for your year]). Its in plain sight, very easy to find.
Warm up the engine, turn it off, disconnect the connector, start engine, set timing, turn off engine, reconnect connector.
I would've scanned the picture from the FSM, but my scanner isnt working.
burnin240sx
For those of you who come across this in the future here is a screenshot from the FSM of 20 deg BTDC
ArticDragon192
Car: 91 Z32 2+2
What would be best for performance without having to get anything higher than 87 octane, 18 or 22, or should I just stick with 20 degrees if i still wanna run 87 octane?
90SXSE KA24ET DREAMS
Car: 1990 Nissan 240SX SE 5spd KA24E-T project
is the timing makrs and is 20 the same for the ka24e. from what i just read everyone was talking about ka24de.
what's it for the ka24e?'thanks.
