stock headgasket or aftermarket?
Ghettorex
So, the headgasket is one of the last things I need to buy to get my car up and running correctly again. I'm not sure if I should just get a stock pulsar headgasket or get an aftermarket one? I havent done much engine work so I dont think it would really matter at this time? What do ya'll think??
Jason
nab911
Car: 93 Nissan 240SX SE
You plan on boostin big?
boost_boy
If you're not planning on running big boost and power, then a nice fel-pro unit and some new head bolts will do you just fine.
Dee
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
figure i need a metal one, im planning on 18-20psi on this rebuild.. not a good idea to run this with a stock unit, right?
boost_boy
Quote »figure i need a metal one, im planning on 18-20psi on this rebuild.. not a good idea to run this with a stock unit, right?[/quote] You'll eventually meet the boost god with this one, but it will last. The metal one is big investment in case you got a bit cute with the boost.
Dee
float_6969
I'll be running a stock Pulsar one. I think i will hold up.
