Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Sat Jan 21, 2006 8:23 pm
As long as it doesn't shroud the bore then you would be good, but I doubt that it wouldn't. The Felpro I used was just about 1mm larger than the bore. If you did use it, it will blow again. But like I have said, the Felpro should be large enough.
