meminto »
https://forums.nicoclub.com/meminto-u95701.html
Sat Jan 24, 2009 3:30 pm
Okie Dokie..
Out of the oven and here is the first shot, so far I have noticed that the material itself has raised about 1.5mm from its original postion and there is some surface cracking, which looks to be about maybe two or three thou in depth. When you consider the thickness of the material this is absolutely negligable..
There is no difference in the elasticity test I performed, no bubbling, no melting, no detatchment from the balancer, its almost come out how it went in...
As I let it cool at room temp which is currently 31 degrees celcius in the QLD Aussie summer, the material is slowly recessing and taking its original form...
I will edit this post once its completely cool...
and lol @ TMS...
Ok here is the result...
After 3 odd hours of cooling, it is back to room temperature. The first thing I noticed is the material was still raised 1mm from the original position, this would be a result of the heat. The surface fractures in the material did not get larger or smaller during cooling.
These fractures I believe are a combination of the heat and the age of the material, however as they are very small in depth they are not of any concern, if they were say 5-7 mm in depth it may have been a very different story..
I got out the drill and drilled into the material in two places to check the depth, the depth increased 1mm, due to the raise in the material. I then drilled in two locations so I could retrieve a sample of the material. It was quite difficult to cut out as it was still firmly adhered to the surrounding casing. I had to remove some more material to the left of the sample I took so I could physically remove it lol...
The sample I wanted is the square above the triangle piece (the triangle piece was the bit i hacked up without care to remove the square sample). As you can see there are still casting marks in the rubber, as I do not know how the balancers were made in the factory, to me it looks as though it may have been some sort of injection moulding, but only speculation....
As you can see the material does have some elasticity, even after many years of operation and a bake in the oven, it is not so brittle..
I cut away approx 4mm off the top of the material, this was still quite difficult as it was firmly attatched to the outer casing, I did my best to obtain a smooth cut, but it was near on impossible...
I hope this provides some useful information on the balancer for the folk out there looking for it
Thanks to niscort for providing the cross section cut of the balancer...
Cheers...
Modified by meminto at 8:59 PM 1/24/2009
Modified by meminto at 9:02 PM 1/24/2009
