RyanSinibaldi wrote:so do you guys think i could just get a fuel pump, maybe an a/f ratio just incase to monitor things, and then run 6psi daily making sure i use 93 octane?
it's not about how much boost. it's about 1) the efficency range of the turbo you're using and 2) power output of the motor. saying 6psi is worthless if we don't know what turbo you are using and other supporting mods. 6psig might be ok or it might not.
in the thread I linked it covered that in a fair amount of detail. the jist is, if you are keeping your turbo within its efficency range and keeping the motor's power output within the injectors capacity you'll be fine. Ckwik posted some math showing the stock injectors to be capable of ~190 hp
keep your motor below that in terms of power and the turbo within its range of efficency and you should be ok.
