WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Mon May 02, 2005 7:46 pm
Just to let you guys know, I'm running the stock pump, broke my Holley...long story, It runs great at 12 lbs of boost with 45 psi base pressure. I'm using 42lb injectors and a huge rail, and the pump is doing a fine job. My AFR's are 11.3 till I get over max torque, about 4500, and then I leaned it out myself to run 12.1 up to 6500.
So if your not using a FMU, then the stock pump is good for quite a few lbs of boost.
Just figured I'd post the info...the "must replace the fuel pump to run boost" theory isn't as strict as we thought.
WD
