stock fuel pressure regulator question
jzamerican
Car: 1990 toyota supra1jzgte powered
1980 ford mustang ka24de powered
does a 1995 ka24de have a fuel pressure regulator on the rail or will i need to buy one to put it in another car
imash the loud pedal
Car: 93 240sx kade 11:1 compression, full assortment of boltons, aluminum flywheel, stage 3 act clutch, header and full hks exhaust, 248/232 cam swap
rail...firewall side with a vacuum to it
jzamerican
so it does come out when the engine is pulled? and does that mean the engine is fed from back to front or front to back?
corn322
Car: 1993 240sx
It's attached to the fuel rail. So it should come out with the engine.
As for how the engine is "fed," you're going to have to refine that question.
jzamerican
is the feed line on the right or left lol
corn322
Car: 1993 240sx
A picture is worth 1000 words:
jzamerican
ok lol i thought the reg would go on the feed line
jzamerican
and could i just t into the supply sice im putting a ka into a carburated ka?
corn322
Car: 1993 240sx
jzamerican wrote:putting a ka into a carburated ka?
That confused me.
If you mean turning a KA into a carbureted one, then you don't need to tee. The line from the pump would just go to the carburetor. Be sure to replace the fuel pump with a low pressure pump.
If you mean putting a KA into a carbureted car, similar deal. Fuel line to fuel rail. Replace pump with high pressure unit.
However, if you are fitting a fuel injected KA inside a carbureted one, I would like to see this.
jzamerican
Carburated car sorry lol I wasn't paying attention last night. There isn't a return line so I thought I could just t back into the supply
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Fuel return, whats that?
Using a carbureted motor you need a lower pressure, high volume pump. Carb pressure runs 0-12psI Typically 5-8psi. You need a vent, and a feed and thats all.
jzamerican
nooooooo lol im putting a fuek injected ka into my mustang and i need to run the fuel lines so can i just t into the feed line so i dont have to run the return line to the tank
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
An aftermarket fuel rail with an off rail regulator will do the trick
