mackdaddy240 wrote:considering the torque you lose from a lightened flywheel is it really worth all the time and money it takes to change flywheels? I decided against it on my car.
you dont lose torque from a flywheel. the heavier the flywheel is the easier it is to get the car moving from a standstill because the flywheel effectively stores some of the energy it took to get it spinning, which in turn you use to get the car moving. lighter flywheels are somewhat harder to use because you have to feather the gas to use more engine power to get the car to start moving, since there isnt a big heavy flywheel helping the engine out.
however it takes energy to get it spinning, so the heavier the flywheel the MORE torque and power it will rob from you. on dynos cars gain torque AND horsepower from lighter flywheels over the ENTIRE range of the power band.
Lightened FlywheelPros:*faster acceleration, more power*tends to wear clutch less (engine speed matches input shaft speed faster when you let the clutch up, big difference with engine braking)
Cons:*Slightly rougher idle*harder to get the car moving from a standstill*$$$
