hannibal »
https://forums.nicoclub.com/hannibal-u1252.html
Tue Aug 16, 2005 4:38 am
I have no experience with this whatsoever, but if my understanding of the # in / # out is correct, would seabrooke need the same in and out since his ECU is already programmed for the Z32 MAF and larger injectors?
Youre not using the SAFC to correct for a different MAF and larger injectors. Its to fine tune a setup the ECU considers 'stock' (a setup its already programmed to handle).
If I'm way in left field, tell me and I'll shut up...
