Sil240 »
https://forums.nicoclub.com/sil240-u6842.html
Sat Feb 14, 2009 6:40 pm
Bro first of all.That is a crazy VAGUE question.Whats good for one person, isn't for the next.Stock turbos vs a T88 --->>>>> LOLZHow can you even compare?
Try SEARCHING first, then try READING second.Then you wouldn't ask such a question as this one.
First go to How stuff works .com and find out how a Internal combustion engine works.Then Find out how Turbos work.
Good stuff to know.And if you think you know enough.
Google How to read a Compressor map
Then Plot a compressor map of a T88 turbo on a RB26.
Your probably not gonna find specs on GTR turbos, so just Plot a T25/T28. (remember theres 1 turbo per 3 cylinders)
Then you will feel great cause you came about your answer on your own. Self Fulfillment will not be the word.
Then you will post up here.To LOCK this thread because you've realized that you question was a bit...... on the uneducated side.
Read up buddy.You learn alot.
Now you know.And KNOWING is half the battle.
