stock clutch fan rb swap
240sxed
Damn I read somewhere from a previous search about using the stock clutch fan in an RB swap. But I can't find it again, I think all the forum rearranging is the reason.
i've searched for stock fan, clutch fan, keep fan in post bodies and topics in the rb forum?
Anyhow I believe it involved using the KA clutch-fan or the fan part or the clutch part, and then a 10 mm spacer somewhere.... but I can't find the exact directions.
300Plus
Car: 1995 S14 w/ Rb25det Series II
everything I've ever read or seen about swapping an RB into a S13 or S14 says and shows that there is def not enought room for a clutch fan. You have to go electric and depending on what mounting method you went with depends on your clearance. I've heard some ppl say that can't even fit fans in the engine bay and have to use pusher on the front of the rad. I plan on going with the twin 12inch permacools, like everyone recomends, plus a pusher on the front
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
If its an RB20, I've heard you can take the stock fan off the clutch from the front, then put it on from the rear. This gives you the clearance you need in the front. You may have to trim the tips of the fan a little to clear a pully.
But this is only something I've heard and I haven't tried it yet. (but i will)
240sxed
Im i think i can get my clutch fan to fit....do you guys think I should run 2 efans on the front of the radiator(pusher), and 1 clutch fan as a puller. or do you think it'll restrict my airflow?
btw i have a fmic...
Ramius83
Car: 1995 240sx SE
Well, it will work definitely, if you can get the clutch fan in there. But the main problem is making a GOOD shroud for the clutch fan.
You can't just slap a clutch fan on a motor and call it a day. There has to be a shroud to allow the clutch fan to "pull" the air from the front of the radiator, so that the air moves through the fins on the radiator, cooling it down.
I know that on my RB26 swapped S14, there is NO way in hell I could get my clutch fan to fit in my engine bay.
240sxed
Ramius83 wrote:Well, it will work definitely, if you can get the clutch fan in there. But the main problem is making a GOOD shroud for the clutch fan.
Well i'll probably trim up my shroudto make it fittheres gotta be a wayhehe
OKRB20DET
Car: 1990 S13 coupe
is it possible to turn the fan around and make it push the air? that way u wont need a shroud
gawdzilla
Car: none
the oem fan is physically driven by a belt on the motor. how can you possibly turn it around and make it a push style??
