Stock clutch fan Q?
lovemy89240
Car: CA powered 1970 datsun 510
Does the stock Clutch fan on the 89 240's push or pull air threw the radiator?
I'm trying to figure out which way to run my electric fan...
Razi
Car: Moo
Is this a serious question?
They pull the air through the radiator, how would it work efficiently as a push fan from where it is? :confused:
Do I need to explain this further?
S13AL
Car: 1991 240sx hatch with blacktop s13 sr20det, HKS Hipermax III suspension, HKS Sport exhaust, Blitz downpipe, S15 Sylvia HLSD, 300zx/J30 5 lug and brakes, and mesh wheels
Why are you switching to electric?
lovemy89240
Razi wrote:Is this a serious question?
I'm just making sure..... rather be 100% than 62%, I more new it was pull because of the distance but you never know crazier things do happen.....
S13AL wrote:Why are you switching to electric?
I just got my mishimoto radiator, and picked up one of there 12" fans from my friend for dirt cheap, oh and the fan was destroyed during the rebuild so hey, less parasitic drag and alittle more go!
Klits562
Car: white s13 coupe
is a 12" fan big enough?
lovemy89240
its either a 12 or a 14 but i havnt overheated yet even when i ran it on 110 octane for 2 hours,
and itr run on a switch that i turn on right when i get in the car.
Dattebayo
lovemy89240 wrote:I'm just making sure..... rather be 100% than 62%, I more new it was pull because of the distance
:wtf2:
Cars move forward. The fan is behind the radiator. This is how you should know that it pulls.
WTF are you on about with this "distance" crap?
Also, the switch is a dumb idea. You're gonna forget to turn it off one time and end up destroying your battery. Hook it up the right way.
lovemy89240
pushing air from the fan would be kinda stupid because the stock fan is too far to push the air threw the radiator with enough force to do anything... i knew this but just wanted to be 100% sure
and as far as my switch...... The Fan Is F-ING Loud theres no possible way of forgeting the damn thing is on haha, it sounds like a truck on full blast, And i do have a thermal switch i just dont like how late it turns on so the switch is temporary until i get a new shinny adjustable one :)
On another note would there be any benifit for running a smaller 2nd fan as a push fan to move the hot air from the engine bay or would this just not help?
S13AL
There is no such thing as a fan that pushes air through a radiator against the flow of air going through on the other side. Air only enters through the front it doesn't exit. So, I'm not sure where you got the idea that a rad fan is supposed to push air out the front of the radiatior.
lovemy89240
S13AL wrote:There is no such thing as a fan that pushes air through a radiator against the flow of air going through on the other side. Air only enters through the front it doesn't exit. So, I'm not sure where you got the idea that a rad fan is supposed to push air out the front of the radiatior.
A honda owner gave me the idea......
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
Dont they sell pusher fans that go infront of the radiator? I think the idea was to make the engine bay look more roomier.
edit*
Here I found some
http://shop.ebay.com/i.html?_nkw=radiat ... rom=&_ipg=
The only negative thing I can think about this is that it wont be able to push as much air as a puller fan. But it does make the engine bay look cleaner
S13AL
-RJ- wrote:Dont they sell pusher fans that go in front of the radiator?
Yes. but, the air is still being pushed in the direction that it is supposed to go.
S13AL
lovemy89240 wrote: A honda owner gave me the idea......
those honda owners :chuckle:
Razi
Car: Moo
I guess you're no better than a Honda owner then? :gotme
I hope you plan to at least learn the basics on how a car works before modifying it.
Best of luck.
lovemy89240
wow, hey now no need to get nasty,we were talking in a parking lot and he asked why i had an electric fan and if it pushed or pulled i said pulled and he looked at me weird, which made me wonder, im not some noob, i just wanted to ask a stupid question, my bad...
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
lovemy89240 wrote:Does the stock Clutch fan on the 89 240's push or pull air threw the radiator?
Oh wow. :facepalm: Dude, if you know the stock orientation of the clutchfan is 'behind' the radiator, why would you ask this question? I don't know of ANY fans that push air through the radiator from behind (thus counteracting the natural airflow while in motion) ... seems a bit inefficient, right? This makes me worry ... please stay away from my car. ;)
lovemy89240
no!
lovemy89240 wrote:
lovemy89240 wrote:wow, hey now no need to get nasty,we were talking in a parking lot and he asked why i had an electric fan and if it pushed or pulled i said pulled and he looked at me weird, which made me wonder, im not some noob, i just wanted to ask a stupid question, my bad...
READ
scotty-2-forty
:squint: Why would you WANT to ask a stupid question? ... Your words, not mine.
lovemy89240 wrote:READ
I did, and it still makes me worry. Is this supposed to explain that you knew the answer prior to asking this question? In that case, you should have educated the Honda owner and never have asked this question here. I'm not being rude, just really confused as to your objective here. :gotme
... and ...
Stay away from my car. :chuckle:
lovemy89240
just to make sure i wasnt losing my mind and thinking bassakwards
... and ...
Stay away from my car. :chuckle:[/quote]
Yea well I dont like s14's anyway :tongue
scotty-2-forty
Ah, very good then ... a moment of brainfart ... we all have'em. :biggrin:
lovemy89240
Kinda like when your putting your engine back in and you look for the headers and you can only find one and you start to panic then you realize its a KA...
S13AL
lovemy89240 wrote:Kinda like when your putting your engine back in and you look for the headers and you can only find one and you start to panic then you realize its a KA...
Thats a serious issue.
lovemy89240
hey it was 3am and i was working from 8am haha
