stock boost
Projekt
self explanitory. What's the stock boost on an RB25?
dreamsOfSkylines
I think 7 psi but I'm not positive.
themadscientist
not PSI .7 kilo which is about 10-10.5 lbs
Projekt
you mean .7 Kg/mm^2? aka about .7 bar?
d240t2
The RB20DET boosted ~10psi stock. I won't speculate about other motors.
Dennis KalmanunStable Hybrids
Projekt
night, was your stock boost rating with or without a stock downpipe?
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
NightXCZ77 wrote:RB20 also has a compression ratio of 8.5/1 which would make sense that it is running the same or almost the same boost as the GT-R engine which runs 11 psi from articles I have read.
Night
Yeah... mine showed 10 on the trial run... and that was at fairly low revs too!!! Just some additional info...
WDRacing
My friend ran his @ 1bar 14.7 psi all the time. All stock except for a FMIC.
WD
meggala
Ihave run my rb25 turbo at 1 bar its fine you might need a restrictor inthe line that goes from to your actuator they can be tricky buggers a mate has a simialr problem to day night try a manual bleed with a restrictor b4 you ditch your turbo also check you boost gauge for accuracy.meggala
meggala
quite a few peopel here hiflow the stock turbo with great results but a t3/4 from your area would be good or you could go the whole hog for a t 4 which are great jsut dont forget the fuel system
bob marley
meggala wrote:Ihave run my rb25 turbo at 1 bar its fine you might need a restrictor inthe line that goes from to your actuator they can be tricky buggers a mate has a simialr problem to day night try a manual bleed with a restrictor b4 you ditch your turbo also check you boost gauge for accuracy.meggala
I think that is basically what a fuel cut defenser (FCD) does correct? I thought you needed to get one to allow raised boost levels so you don't hit fuel cut? I think it sends an electronic signal so the car thinks its running stock boost, when in fact, it is boosting more. I do not know of any boost controller that came with this option though. I think it is something you attach to the ECU.
Just an idea :confused:
Anyways, I love your cars Night and Meggala
Johann
rbsileighty
bob marley wrote:I think that is basically what a fuel cut defenser (FCD) does correct? I thought you needed to get one to allow raised boost levels so you don't hit fuel cut? I think it sends an electronic signal so the car thinks its running stock boost, when in fact, it is boosting more. I do not know of any boost controller that came with this option though. I think it is something you attach to the ECU.
Johann
Correct me if i'm wrong... but I think the fuel cut is beyond the limits of the factory ceramic turbo. I'm going with a new comp before I get another turbo, so i'm not even going to mess with a FCD. I bet it's awesome being able to turn the your MKIV up to 17psi on stock turbos!
Projekt
and FCD just tricks the computer, but it doesn't raise boost.
bob marley
Projekt wrote:and FCD just tricks the computer, but it doesn't raise boost.
I know, thats what I meant :) . But don't you need something like that before you raise the boost?
Projekt
you don't need it, but it sure helps.
cyris3d
Projekt wrote:you don't need it, but it sure helps.
so you can turn up the boost with out a FCD.. and it wont cut fuel?
Projekt
yup :0) i'm sure you can trick a sensor though without having to buy a 200$ box.
bob marley
Maybe the FCD is more expensive for other cars; I'm not sure. But the one for the Supra/Mr2 was 100 from greddy new, and I just bought one used for $40.
You can also do a Free FCD (FFCD) mod. Here is one way for the supra: http://www.mkiv.com/techarticles/ffcd/freefcd.htm. I know there is another way too. My friend made his for his mr2 a different way.
Johann
Projekt
yeah and you can make a boost controller for $6 too :) :)
