stock boost sensor?!
FriedEGs
Car: 1995 SE, Roast Beef!!
Where is the stock boost sensor located? I realize after dropping in my motor and driving around, that i don't have this hooked up. (see pic below) Is it located on teh firewall of the r33 clip?
This must be the reason my car is cutting boost at wot...
Thanks!
Shocker
Car: 89 240sxHB rb26/30
just cap that, it was for the stock factory boost gauge.
240z4u
Car: '95 Nissan 240SX
Its probabally not cutting boost, its probabally going so rich that its stumbling.
My car did the same shiz when I had a vac/boost leak. cap that off along with any other holes you left open.
evan
NightKids2
Yep, I used that to run to my boost gauge.
I forget exactly where the boost cut solenoid is since mine is now on the other side of the car lol.
But essentilly its small metal cylinder on a bracket near the turbo, has a plug and wires on it. If your not going to use it (i.e. you have a boost controller of some kind) then take the tubing and route the two ends together on it like a U and make SURE its still pluged in, cause the ECU likes it whether you use it or not.
FriedEGs
Ah, so this sensor doesn't send any info to the ecu?!
Abdo
Car: S13 RB25DET
NightKids2 wrote:Yep, I used that to run to my boost gauge.
So I have to use that? Because I took mine completely out.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
zer...56758
Crazy, both posts were right next to each other!
Shocker
FriedEGs wrote:Ah, so this sensor doesn't send any info to the ecu?!
nope we dont have MAP sensors stock.
FriedEGs
l0nestar wrote:zer...56758
I was trying to find out about the stock boost sensor... that thread talked about the boost solenoid..
