Cjmartz2k wrote:Yes, but HKS makes the worst BOV's on the planet, unless you like leaky crap that's only good at making noise. Are you trying to change BOV's because you want to run more boost than the stock one can take, or do you want the super cool noise?
I'm just guessing here, but I believe this reputation is from the "old" style of the HKS with the bolt on the back.
People thought you needed to adjust it using this boltThis bolt should not be adjusted at all. If you try to adjust it, it will cause it to leak.Because of this poor design they redesigned it to remove the bolt.
