Stock 25det ECU + Boost?
blurrbosi
Car: 240's
Hmm... wondering if the ecu has a stock fuel or boost cut/limit?
Any knowledge would be great.
Shocker
Car: 89 240sxHB rb26/30
no, it will cut fuel and pull timing if it senses knock tho. Otherwise boost is endless theoretically...
blurrbosi
Car: 240's
hmm... I doubt there is knock @ stock 12-13lbs...
U think it is blowing out spark @ only 13 lbs? Gapped @ stock 1.1....
FriedEGs
Car: 1995 SE, Roast Beef!!
1.1 mm? That might be too high.. I think stock is around .8mm (.031 inches)
1.1 is around .042-.043?! Most turbo applications are usually around .031 (including our motor)
blurrbosi
Car: 240's
hmm..
