drifting{s13} wrote:thnks man i apreciate it, but i do plan on doing time attack and drifting so all the information i can get is awsome now about that radiator where can i get one and how to install it ? and i do have a 11lbs flywheel already i forgot to mention that lol but i am getting ready to buy some crower 264 cams and just wondering if that would help alot
im sure you could order a koyo radiator off some internet web site... i wouldnt go ebay but its up to you... um... i would flush cooling system before removing it, then im pretty sure its just a matter of taking all the piping off and unbolting the radiator, then putting the koyo radiator in.. the radiator you order should be made for you car so it should fit the same way as the old radiator... while you are at it you might as well remove mechanical fans and put eletric fans... there are ways of doing an eletric fans that are complicated, but the easy way is just wiring it strait to the battery and either wiring it to an aux fuse or just soddering a fuse into the wiring itself..
another suggestion is if you are gonna be using the car just for racing, take the ac compressor off...
another way to increase horse power for free is advancing the distributor 2-3 degrees... be very carefull doing it though..
