RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Mon Oct 06, 2008 7:13 am
The larger gives higher peak HP, the mid-size 5/16, gives broader range of power and is the better choice. You don't drive around at redline all day long. What ever you buy, DO NOT tighten the bolts down in ft lbs. They are tightened in inch lbs. If you don't have a inch lb wrench, just use a socket/screw driver attachment and wear a leather glove. This limits your ability to torque to inch lbs.
