Stillen XD Cross Drilled Rotors S13
KiLo64
Car: None at the moment
How well do they perform? Are they compatible with z32 calipers? On the website it says that itworks best with the stock calipers but it doesn't mention anything about compatibility. Any input would be appreciated.
Thanks!
C-Kwik
The Z32 Rotors are a good inch bigger in diameter than the 240sx rotors. They are also thicker as well. So essentially, the answer is no. A stock 240 sized rotor is not compatible with a Z32 caliper. You have to use the correct Z32 Rotor with it. And bear in mind, there are 2 different thicknesses of Z32 rotors that had been made.
