Fearspect »
https://forums.nicoclub.com/fearspect-u209440.html
Mon Oct 15, 2012 8:30 am
It is very hard for me to compare these Oil Cooler options because they don't provide direct numbers. Can someone let me know which is the superior product to install in my car, cost on these not being a real issue (we're talking maybe $50 range in cost difference between them):
Stillen Oil Cooler: Boast a temperature reduction of 30-40 degrees farenheit
Nismo Oil Cooler: States that it is 300% more efficient than the stock cooler
Z1 Full Flow Oil Cooler: Implies that other products to not provide what it does, that 100% of the Oil travels through the cooler before being supplied to the engine.
Z1 also offers a 'patch kit' that allows you to convert their oil cooler to a full flow. Would the ideal set up here be to pick up a Nismo/Stillen then upgrade them to full flow?
What I see most on heavy duty builds is the Stillen. Did some searching and haven't come up with any really concrete comparisons.
If it helps, my car is currently running somewhere around 400 HP at the crank (I believe a low estimate based on catback exhaust/test pipes/downpipes, UR pulley, Specialty Z Chip w/ Boost Jets, Single Air Intake). I will probably eventually get her around 500-600 HP when all is said and done and want to upgrade parts, where possible, only once.
Appreciate the help!
