The nut is stuck. I've been pulling as hard as I can at the nut and can't get it to move. What's an impact/breaker bar and where can I get it?Florida240sx wrote:Is the nut stuck and not coming loose. or is in turnign within the bushing? If it's fixed then use an impact/breaker bar. If it's inside a bushing then use an impact and put pressure against the old bar againt the bolt. That way the bolt is binded and will keep it from turning.
thanksCYO44Baseball32 wrote:will try to take some today
Yea.. but I'm lowering it this weekend and putting my wheels back on next week, so hopefully next weekend I'll get some new pictures and post them up. ThanksIvoryG37 wrote:IP37,
ur ride is sweet, you have anymore pix of this?
yup. the factory is hollow and stillen is solid, that was their reason for the stillen bar being smaller. but he said he didn't have that problem, so i'm not sure what's going onmikelr wrote: Is the factory bar hollow and the Stillen bar solid? Most aftermarket sway bars I've seen are larger in diameter than stock.
Mines was bigger... lol and my bushing didn't fit loose like that. I think you should ask for new ones from stillen.IP37 wrote:
