It's been on my car for quite a while... Close to 5 years now.
Time to get a new one!
Stillen again, or Racingline?
Just aggressive driving on crappy CA mountain roads. Same way I busted by CV boot last year.Buyingcoilovers wrote:why do you think it broke?
do you take it to track?
6SpeedinCoupe wrote:5 years is a long time. I think the money was well spent.
I'm pretty sure stock end links work with the Racingline RSB. Can anyone chime in?6SpeedinCoupe wrote:I'd say give Racingline a shot since it is adjustable and something new to experience. I'm not sure if the same end links will work with the RSB, I kind of doubt it.
In the past, at the time of the OP's purchase, they did have that problem. But I stumbled upon this http://www.nissanclub.com/forums/2007-2 ... y-bar.htmlel_blacky06 wrote:If you're not aware, Stillen had a design flaw that causes the sway bars to not properly function correctly. Too many bars including my own Sway bar causes to snap in the same way yours did. Check it out on their website to get more into on that
Thanks, I had no idea!el_blacky06 wrote:If you're not aware, Stillen had a design flaw that causes the sway bars to not properly function correctly. Too many bars including my own Sway bar causes to snap in the same way yours did. Check it out on their website to get more into on that
The Altima coupe handles just as a 3,200 FWD should, with 62/38 weight distribution for the v6. There is no surprise here.seldomseen wrote:The Altima Coupe surprisingly handles like crap.How are the aftermarket sway bars improving the handling characteristics of the coupe specifically?
Nah there's more to it than being a 3200lb FWD car...the OEM tuned suspension set-up isn't quite were it should be on the coupe. The '12 Accord coupe V6 is 3500lbs and handles more nimble than the Altima Coupe V6. Nonetheless, the swaybar option seems like a worthwhile option to improve matters a bit.alphapig wrote:The Altima coupe handles just as a 3,200 FWD should, with 62/38 weight distribution for the v6. There is no surprise here.seldomseen wrote:The Altima Coupe surprisingly handles like crap.How are the aftermarket sway bars improving the handling characteristics of the coupe specifically?
Essentially, it plows head first into corners.
However, I can hit my mountain pass just as fast in the AC as in my modified Miata, mostly because of the plowing. Understeer is much more noob-friendly compared to over-steer. Having said that, the Miata is over 9000 times more fun and, if properly pushed, is faster in the mountains.
Thicker rear sway bar slightly reduces understeer. HIGHLY recommended for making the "crappy" handling Altima handle better.
Hey alphapig, any specifics as to what the typical weak links are within the suspension components, when you have all of those parts installed on the altima? My BC's just came in and the RSB/tower strut bar are next on my list. I just want to be prepared for the worst and make sure I have cushion in my wallet ya know.alphapig wrote: That said, I've had coil overs forever (weird modified frankenstien setup in my case). With a strut bar, sway bar, and coil overs you are more likely to get rear wheel hop before it under-steers like a pig. The real problem with heavily modifying the suspension is that sh*t breaks. I would compare the handling characteristics at the Acura RSX, which was a great little car, but the RSX can take actual abuse where the Altima falters.
You mean labor or actual parts?seldomseen wrote:What's the typical cost of having the OEM sway bar swapped out and replaced?
