its a matter of preference and what your performance expectations are for the upgrade.
with a turbo, your gains will be more significant in the upper rpm range, but you may see a fair amount of lag in the lower range, depending on turbo size and single vs twin turbos. fuel economy should be least impacted by turbos, if not improved, because turbos scavenge otherwise wasted energy in the form of hot exhaust gases. its probably the most hardware/labor intensive FI option, as well. but also, the most tuneable/tweekable. (assumption. correct me if im wrong here, guys.)
superchargers and roots type chargers should see good, steady gains through pretty much the whole rpm range, over N/A power. since theyre belt driven like any other accessory, they take hp to make hp, but obviously more than make up for it. because of this though, your going to see some decrease in fuel economy compared to N/A during normal driving. (ive heard the blowers on top fuel drag cars use around 350hp at full load to make the monster power they do!) also, with the roots type, im pretty sure you cant clear a stock hood so, there that...
while i dont have either, base your selection more on which sounds like it would best suit your plans for the car, because like i said, its a matter of preference.
that said, id really like to see someone chime in that HAS had both setups.
