One Crazy Max »
https://forums.nicoclub.com/one-crazy-max-u77654.html
Sat Dec 13, 2008 12:56 pm
i think when im ready, im gonna buy the progress rear sway bar from the 02-06 altimas, and fit it up to my sedan. i have the racingline endlinks.
now you might be thinking that it probably wont fit since i have an 07 sedan, and the bar is from a 3rd gen. the difference between the stock RSB's from both cars is the mounting angle to attach to the endlink, thats it. but since i have the racingline endlinks the angle can be adjusted to fit the 3rd gen bar.
btw, if i were you guys, and you have the racingline endlinks, and you want much less lean than the stillen bar (not to downplay it at all) i would go for the progress bar.
stock 3.5SE - 18mm (hollow)stillen - 19mm (solid)progress - 22mm (solid)
and the price for both of them are not that far apart from each other.
thats 3mm bigger than the stillen = big difference.
the only reason the progress bar will not fit up directly to the stock endlinks is because it was made specifically to mount up to 02-06 stock endlinks and also the two bars a very slightly different in shape, likewise for the stillen RSB for the 07+
Modified by One Crazy Max at 6:47 PM 12/18/2008
