stillen rotors
pathfinder_se_black
Car: 2000 pathfinder, FG2 civic si
are they any good for the r50?
pathfinder_se_black
stillen vs oem?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
are you talking about the drilled/slotted ones?
I dont know about the price difference, but if the stillen rotors are more expensive i probably wouldnt use them. You might see if you could get a set of brembo blanks for the car, they are cheaper and OEM quality if not better than OEM...
you dont need a drilled or slotted rotor because you probably arent going ot be pounding on the brakes.
you could consider getting your rotors turned, thats about as good as getting new ones.
fueler
Car: 2 Nissan's
2 BMW's
elwesso wrote:you could consider getting your rotors turned, thats about as good as getting new ones.
I've had bad luck with resurfaced rotors on my R50. They always warp and shake at high speeds and under hard braking. The small discs on a 5000 lb car with drums in the back just don't do it justice. I purchased some brand new Mountain brake rotors for my R50 from http://www.importRP.com at only $40 each. They have a wide variety of brands, ranging from $30 each to $90 each.
(their website only shows Brembo, OPparts, and BPI but if you call, they will give you the entire list)
Spend the extra few bucks and save yourself some headache, trust me.
pathfinder_se_black
haha i definatly wont be pouding on my brakes, thanks for the help i think i might just buy the brembo blanks with pads.
fueler
Car: 2 Nissan's
2 BMW's
yes, go blank, the drilled/slotted rotors are like cheese graters to your pads.... beware of the cd/slotted ones on ebay, because those people buy blanks and then drill them theirselves in some garage, and those are prone to cracking within 5000 miles.
pathfinder_se_black
fueler wrote:yes, go blank, the drilled/slotted rotors are like cheese graters to your pads.... beware of the cd/slotted ones on ebay, because those people buy blanks and then drill them theirselves in some garage, and those are prone to cracking within 5000 miles.
thanks for the advise, i found some brembo blank rotors on tirerack.com.. imnot sure if i should get OEM or high performance pads from that site as well.
