kyle@stillen »
https://forums.nicoclub.com/kyle-stillen-u83599.html
Fri Jul 11, 2008 12:51 pm
Step 1) Do me a favor and look at the part number on the box that it was shipped in and let me know what that part number is.
Step 2) Depending on how well they prepped it, the paint might stick without primer but I HATE it when painter's don't use primer...I've had horrible past experiences with that scenario.
Personal opinion- Judging by that close-up picture, they did not properly prep the part. Those little fish eyes indentations shouldn't be there and I promise you they were not caused by baking. In fact, here are some explanations to the issues you are having...
#1) If they baked the part, it could explain the poor fitment. Urethane is injected into the mold at very high temperature. Urethane material has a "memory" to it and it will not lose its shape. No matter how hard you turn it, twist it, step on it...Whatever, it just won't lose its shape...Unless you heat it. If they baked the part then it could have warped somewhere or it could have altered the shape of the part enough to effect the fit and finish.
#2) The baking process does not cause "fish-eyes." Which is what those little indentations on the edges are. That is caused by not properly cleaning the urethane. When the part is manufactured the mold needs to be treated with a release agent. This release agent allows the parts to be seperated from the mold. The problem with the release agent is that if it is not properly cleaned or sanded down the paint will not adhere properly because the release agent will not allow the paint to stick to that area...Think of what happens when you pour oil in a bottle of water...They don't mix. Basically it's the same thing going on with the paint and release agent.
So, in my opinion, either they baked the wing and they possibly altered the shape due to the heat. Or, they did not properly prep the part and the paint is not adhering...Or both...
But, like I said, check the part number on the box the wing was shipped in. Or, if your body shop takes off the wing again check the part number in the wing itself. This will tell us if you have the right wing...If you don't have the right wing then it's on us...But, I would be very surprised if that were the case.
I know the next question is going to be..."Well, why doesn't STILLEN simply prep. the parts before they ship them." And it's a good question. The problem is that a properly prepped part is not pretty. Basically you need to sand it and scuff it down so far that it almost looks white. If we sent out the parts prepped and ready for paint, we would be getting returns alllllll day long because the out of box appearance is not pleasing. We know this because it has happened. We used to prep everything before shipping it and people did not like the way it looked when it arrived. They thought it was defective or there was something wrong with it so they'd send it back...
I hope this was helpful!
