Stillen lip and rear spoiler install
All things Altima Coupe.
jdeb101
Car: 2008 Altima Coupe 3.5SE
So finally almost a year later my pieces are in the shop being painted! WOOO! I think I'm going to do the install myself. Who here has done this? Stillen includes pretty good instructions on how to do it, but just want to hear from you guys. Was it hard? Did you sand down the body before hand, or can I just tape it right onto the paint? Is the tape included strong enough or should I use some excellorator?
TIA. I'll be sure to post pics once its all done! :)
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
I installed the lip myself on my 2008. I just prepped the area by cleaning it well. It held on just fine for nearly 3 years until I took it off :) It was difficult to take off!
GrayCoupe
Car: Altima Coupe 3.5
I did the install myself I would suggest some light sanding to dull the surface in order to have a good bond.
jdeb101
If you guys think it would hold well without sanding the body I would rather just stick it on there. Also, jw did you guys have to do any sanding or anything beforehand or did the pieces fit well right out of the box?
Rmuth25
Car: 08 Altima Coupe 2.5s CVT [Premium & Tech Packages]
Sanding is overkill. Just make sure to use a good paint cleaner to get the wax off and be sure to not pull the red film too hard or it will rip.
jdeb101
Rmuth25 wrote:Sanding is overkill. Just make sure to use a good paint cleaner to get the wax off and be sure to not pull the red film too hard or it will rip.
kk cool. I also wanted to ask, how did you guys get the holes in the front lip black? I think I read someone on here used tape??
jdeb101
Anyone???
GrayCoupe
Paint black, or any other color.
This is what I did
1. Pre-fit your front lip spoiler
2. Trace out the openning with a crayon
3. Take off the spoiler
4. Tape off the area you dont want to paint
5. Lightly sand the are you are painting
6. Clean the area with rubbing alcohol
7. Paint & Clear!
Rmuth25
You could use some type of vinyl under the lip to make the holes black. Therefore if you ever part it out you wont have two black spots!
jdeb101
Rmuth25 wrote:You could use some type of vinyl under the lip to make the holes black. Therefore if you ever part it out you wont have two black spots!
I think that's the way I want to go. Is there some special type of vinyl I should be looking for? Where could I get it at?
