*cough* dampers *cough* *cough* looladidas2go wrote:
Thats weird? Everything Ive ever installed from them has worked to the letter. I would contact STILLEN about this. Maybe there were mistake made, they would like to here feedback about
I saw a Stillen rep reply to another post about the 6MT install, so I am sure my post was also looked at. Don't think another mailer would do much. Although I am looking for answers to some of my ?'s if he could post back to this thread.adidas2go wrote:
I just was looking for a few more things in this kit to tie up the loose ends, rather than leaving everything vague and hanging out there. Installing this once would let even the most idiot part-time mechanics (like myself) see the gaps.
I installed a KnN filtercharger setup in my old S2000-I am not sure if I was expecting too much going in to this install. The KnN was much more complicated, but way less confusing. The install write up was right on leaving nothing to "figure out." Took less time and I was 100% comfortable. They also recommend resetting the ECU (disconnect neg terminal + stand on brake)-should this be done with the Stillen?
No worries man, I have a CVT. And if there were no other people with issues, then maybe its just me (and a few of my friends, and a coworker..) <shrugs>. I'll take a look at it again, but some of the issues that I had can be easily seen when you look at your instructions and my write up. Either way I am cool with it-the way I have it does the job.kyle@stillen wrote:
Hey Strikly,
Sorry for not answering your questions on this thread.
Unfortunately right now I don't really have any good answers until we can get a vehicle in for some first hand inspections. It was a total screw up on my part and I take full blame for the mistake. I thought that the intake had been signed off for the 6mt's when in fact our engineers had sent me an email clearly stating it had not...I greatly apologize for the inconvenience. If you wish to return the intake in exchange for an Injen just let me know and I will get everything taken care of.
I am sure the issues you had with the instructions were directly related to the fact that the intake you received was not specifically designed for your car. I haven't heard of any other complaints with the intake instructions so I can only imagine that the confusion stemmed from the different applications.
I am really sorry and extremely embarassed for the mistake I made...If you have any questions or would like to swap out that intake for the Injen just shoot me an email at [email protected]
I can just imagine opening the hood with a turbo under it, and it flaps in the wind.... Wheres the article on it lol...adidas2go wrote:
What was wrong with the hood dampers? I installed the very first ones, with absolutely no problems....
I will take apart our car this weekend and go through the installation myself and take note of each of your points. I will first go through with just following our instructions and see how it works for me. Then I will review all of your notes and see what I can come up with.striklybidnis wrote:
BTW-if you refer to the 6MT problem thread, there is the same MAS bracket screw issue that I had (had to crank the factory screw hard resulting in breakage); 'cept they described it as coating the threads.
If you can please address the following with the CVT setup:-The rubber hose to the transmission that was clipped to the airbox-where does this go? Should I just tack it up like I did?-How do I secure the remaining air flow components? Just tack it?-Which screws (factory Vs Stillen-because they are clearly different) go where (mount Vs filter)? -How can you use a nut on a bolt when you can't get to the other side of the mounting spot?-How/where do I secure the MAS wiring?
Like I said, I installed mine, by the instructions. I even had it written up, in my install thread. I installed the dampers like yours, and the hood didn't close properly. If you remember this post by Josh, they have talked with the manufactures, and there is no problem of lubrication whichever way you install it.mcheddadi wrote:nope you read right
Stillen intake problems:http://forums.altimas.org/zerothread?id=339725
Stillen dampers problems:http://forums.altimas.org/zero...age=3
I even made a video about it here:http://www.youtube.com/watch?v=rCGUEZJLbAc
Josh@Stillen wrote:Hi guys,
We have new instruction sheets, with some additional photos, hopefully that will assist in installs.
In regards to the struts themselves, and whether they are rod-up or rod-down, it is typically advisable to have the strut body above the rod for lubrication purposes, this is for struts that remain in that position.
Our R&D department had spoken to the manufacturer of the strut before completing the kit, and they confirmed this was no problem for this setup. The struts are not installed backwards!
Here is a link to the instruction sheet: http://www.stillen.com/product...t.pdf
Still as sturdy as ever, given me no problems. Im not gonna write an article on the hood struts, they come with detailed instructionsLongBeachCoupe wrote:
, you have to put the upper brackets the exact same way I did in the picture on thread to have them rod down without any obstruction when the hood is closed and with the added bonus of a SMOOOOOOOTH opening like in the video. Otherwise, if you do it the stillen way (rod up) it will open the hood up violently if you don't hold it all the way up. Trust me, I've tried it rod down with the brackets my way and stillen's way and rod up with the bracket's my way and stillen's way. there is absolutely NO way that I'd go back to stillen's way because it looks all flimsy like and cheap when I open it without holding it all the way. Anyhow, I've made a video to show it and wrote 3 pages worth of explanation with pics so either believe me or stay in denial forever lolLongBeachCoupe wrote:hood didnt close because you had the bracket on the hood, facing the wrong way, its gotta be flipped around as well.
give it a try tonight
a good articles manager posts all DIY's, even ricer ones hes not interested in...
adidas, give it a shot tonight, and id bet a big mac you eat your words and like it MENDI's way better.
does it open like this?http://www.youtube.com/watch?v=rCGUEZJLbAcadidas2go wrote:This is the 4th set of hood shocks I have installed on my cars. These are not any flimsier than any of the rest. Its not broke, Im not gonna fix it.
I like the slower way, your right. But when I tried that, it didn't close right. Ask Robert. I was at his house when I tried it. If I had a car right now, I would try it againLongBeachCoupe wrote:hood didnt close because you had the bracket on the hood, facing the wrong way, its gotta be flipped around as well.
Please look for a review on either Saturday or Monday.
Ok-I will tell you what I did before: I disconnected the batt, reconnected and started; the CEL was not on. I turned it off, turned on again and the CEL came on. I then fixed the windows and the CEL remained on...adidas2go wrote:No, but you unplugged stuff, with the battery connected. You can't do that on these cars. Disconnect your battery for 5 min. Then go through the FAQ's and reset your auto windows
They won't try to f me with the HID and intake installed? I kinda wanted to see what Kyle came back with before going that far.adidas2go wrote:weird, take it so nissan
Well, I have seen posts by him in other threads all week-especially when it comes to making more sales. He has even started a thread about headers the other day...$1600 for 20 HP bwahaha...might as well wait for a turbo kit to drop.adidas2go wrote:Bro, he doesn't have every second to get on here. I caught him on the telephone today by sheer luck. I have been calling him for about 3 weeks now, and just got a hold of him. I will send you an email with his extension at STILLEN, so you may get in touch with him. Give him a chance man, they have been running rampant for months now
