scrutmonkey »
https://forums.nicoclub.com/scrutmonkey-u89865.html
Wed Apr 02, 2008 8:17 pm
I posted this on nissanclub as well, figured it will help people with the install.
Sorry for the late post, kit just rolled in today. Install is on delay due to rain....stupid rain.
I read the instructions and looked on the site, but took some pics for those still curious about how the brackets are supposed to be oriented and quality.
Here is a pic of the dampers and orientation from the view of looking at the front of the car...
Bottom plates have the ball pointed in and flapped down...thats probably why you need to notch the baracket on the headlight brace so there is space for the locknut to sit.
Install Instructions come with kit and are on the Stillen site.
Each of the 4 sockets have a small metal pin that locks the ball in place. jusrt pop off the pin, slide it out then pop in the ball, insert pin, snap it closed around the neck of the socket.
This last pic isjust a wider view. The sockets are threaded onto each end of the dampers. i took some time to find the best orientation to have the "Stillen" name showing as NISSAN4LIFE had installed his.
The socket is secured by the nuts provided. I used 2 socket sets to tighten them together.
Hope this helps.
EDIT:
Here's 2 close up of the ball an sockets.
Top Bracket
Bottom Bracket
